Ana içeriğe geç
Model A1213 / 8, 16, or 32 GB capacity
216 Soru Tümünü görüntüle
Can I test the Mother board only using the USB cable?
I am trying to test a 1st Gen motherboard only. It does not have a battery attached or headphone jack.
Should Itunes see it when it is plugged into the USB port of my computer? Or does it at least need a good battery attached?
I plugged it in and got no indication that it was connected on the computer screen.
This was purchased used and I was trying to prove that it works. The previous owner stated that it was tested with a fire wire cable.
Thanks in advance,
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
no, the cable isn't enough for that - the battery would be the minimum.
and for the firewire thing - you can only charge the ipod touch with it - syncing is not possible with those cables
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
tarafından
Yorum Ekle
Markus, Thanks ! That makes me feel better about my purchase. I will have to get a battery on it.
Puan 0
1 Yorum:
you're welcome, as a additional information - i#ve tested it on a 2nd gen ipod touch - when i plugged in the cable, it try to boot and then restarts - the power from the usb cable isn't enough to use the upod . but it tried to start
tarafından
Yorum Ekle
Yanıtını ekle
barlowdo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 1,507
