Ana içeriğe geç
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
173 Soru Tümünü görüntüle
Why does it say "Your Xbox can't recognize this disk."?
When Iput any disc into the console game or DVD or audio CD it always comes back saying and I quote "your xbox can't recognize this disc. Make sure it's an Xbox game, DVD movie, or audio CD, also check to see if the disc is dirty or damaged. Remove disk to continue. I hope somebody has the answer to this problem thank you?
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
snowman2532, most likely a failed laser. I'd suggest that you:
1) Use a commercially available lens cleaner and see if that helps
2) Clean the laser of the drive manually.
3) Finally replace the optical drive. It's simple plug and play and all you need to do this is to follow this guide
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Old question, but something any new readers can try
I got a 2002 OG Xbox because I threw a bid on it 24 hours before the eBay auction ended, thinking I would lose it, but at the same time I'd have a good parts unit for the non-married parts if it was beyond repair. Nope, I won the console.
I didn't know the exact year out of the gate, but once I got it, I knew it was a Thompson based on the age and drive tray. It wouldn't read a disc out of the box, but it took a cleaner disc (ignore the color, Epson's 3LCD filtering is weird with nearly pure green):
Once I let it run through its process, this game was run through it, but it had read errors at first (I tried another; see how rough the label is thanks to parental Sharpie treatment, and my failed cleaning attempt:
It took a 2nd copy I had on hand (I'm working on a replacement cover in color) perfectly. Same result when I wiped my "parental ownership dispute" copy down:
It even played solid for a good 30 minutes-1 hour, at least with some old GTA: SA save files I found on the console.
Don't run out and buy one of these discs (the odds of these things working is low, especially on Samsung SDG drives) but if you can get it for less than $20 (I paid $15), it may be worth a try. Consider it "burn money" at that point, since it only fixed for 2 days.
Puan 0
Yorum Ekle
Yanıtını ekle
snowman2532 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 98
Her zaman: 12,167
