Ana içeriğe geç
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
Toshiba Satellite P50-A Bios password removal
I have a nearly year old Toshiba Satellite P50-A. Recently I shut down the computer to install windows updates and when I booted up again it went through the Toshiba splash screen and then prompted "Enter password". I know this is the bios password however I am positive I did not set it. I have already tried removing it by taking out the battery and CMOS battery and draining power but that did not work. I also tried using "Toshiba" and "TOSHIBA" as I have seen them listed as backdoor passwords. I cannot find the reset pins anywhere on the motherboard and no one online has had this problem on as new of a laptop as mine. Toshiba no longer covers this under warranty so I need some help! Thanks.
Bu iyi bir soru mu?
Puan 4
2 Yorum
I have a nearly year old Toshiba Satellite P55t-c5114 . Recently I shut down the computer to install windows updates and when I booted up again it went through the Toshiba splash screen and then prompted "Enter password". I know this is the bios password however I am positive I did not set it. I have already tried removing it by taking out the battery and CMOS battery and draining power but that did not work. I also tried using "Toshiba" and "TOSHIBA" as I have seen them listed as backdoor passwords. I cannot find the reset pins anywhere on the motherboard and no one online has had this problem on as new of a laptop as mine. Toshiba no longer covers this under warranty so I need some help! Thanks.
tarafından
I have toshiba p50t - b, i cant find the reset pins. Thanks
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
I couldn't get the laptop to boot from CD so I resumed looking over the motherboard for a reset pin. Eventually I found 2, JRST2002 and JRST2501. I found that JRST2501 did the trick! Just jumped it while booting and it wiped the password. I hope this helps anyone with my same problem!
Bu yanıt yardımcı oldu mu?
Puan 8
14 Yorum:
where are the pins can you send me a picture??
tarafından
Thank you!!! I got a great deal on a Toshiba Satellite P55T-A5202 for under 200$ but it had a bios password which was successfully resolved by shorting the JRST2501 pins as mentioned. Thanks again good sir
tarafından
I have the same problem on a P50A. Powered up while shorting JRST2501 and it worked. Fantastic! Thank you very much. Hated to strip and discard this computer. Only a little over a year old.
tarafından
Glad I could help! Toshina charges 70 bucks for them to fix a problem that can't be predicted or prevented. Sad that it happens on nearly brand new computers
tarafından
I need a picture, please!!!!!!!!!!!
tarafından
9 tane daha yorum göster
Yorum Ekle
Your sound like virus attack to bios. i suggest you to flash bios
you can get flash loader from below link
https://support.toshiba.com/support/view...
Note: you own risk to flashing bios. make sure you are running with unprintable power supply if your battery unstable.
Cheers!
Puan 1
2 Yorum:
Thanks! I will give it a try
tarafından
This was s hard to find ,, I have Toshiba Satellite P55-A5312 btc202-b 94v-0 e220370 i5 Intel Password was set by 6 yr old
tarafından
Yorum Ekle
I just posted a pic of the P50A motherboard showing JRST2501. It is the center pair of the three that are right by the sd card reader metal cover. The pic is on the media manager.
Update (03/24/2016)
Okay just figured this out. Here is the pic.
Puan 1
Yorum Ekle
I´ve got an Toshiba Satellite C50-A-1M0 notebook here, without bios password. I can´t find cmos, jcmos, jpw or jrst2501 on my mainboard.
Everything is only with c, d, b, pad or q, one Jack and one Fuse. Where are the contact points for this board? I can´t find them. Even not under the stickers.
Can I use the bios flash from this link above by Buddhika Mahesh even when I can´t get into bios?
https://abload.de/image.php?img=20190612...
Puan 1
3 Yorum:
Same thing, unable to locate a set of jumpers, or anything I can short together to reset the BIOS. 09-05-2019
tarafından
Am ssirajj this article was helpful, bcos it worked thank you very much may Almighty God expand your knowledge
tarafından
i phoned toshiba. they told me to send this laptop to them. they will soldering a new bios-chip on mainboard fo 70€ because it is not possible to reset this model with JRST2501 pins because this model has not that JRST2501.
i found that on the net. maybe it helps.
https://www.justanswer.com/laptop/7u6gl-...
thats all i know. so far ...
tarafından
Yorum Ekle
I have Toshiba dynabook satellite k21. I have forgot the bios supervisor password. How can I remove the password?
Puan 0
1 Yorum:
Toshiba satellite 79511912k can i favor for same problem .how can i get bios password thanks alot..
tarafından
Yorum Ekle
Yanıtını ekle
Austin P sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 56
Her zaman: 18,754
