Ana içeriğe geç
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Soru Tümünü görüntüle
What size torq-set screw does MacBook Pro 15" use?
The tools listed here MacBook Pro 15" Unibody Mid 2012 Logic Board Replacement are not helpful. I'm looking for a torq-set screw size which come in size 6, 8 or 10. I do not know the correct size for the screws which hold the Airport Bluetooth Card Bracket. The screws can be seen in this photograph.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
4 Yorum
Which MBP 15"? Please give us the last four figures of your serial number.
tarafından
Serial No.: CO2JM3FMDV35
tarafından
Apple MacBook Pro "Core i7" 2.6 15" Mid-2012 Specs
Identifiers: Mid-2012 15" - MD104LL/A - MacBookPro9,1 - A1286 - 2556*
tarafından
william hit the correct guide. Each guide lists the tools needed in the peramble.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The logic board replacement instructions seem to indicate that it uses T6:
Edit:
The screws in your image are most definitely Philips. I can't place the location against anything similar in the guides, but I'm guessing #00 based on the AirPort/Bluetooth guide:
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Replacement
Edit 2:
I found the item depicted in the picture. It appears to be one of the retaining clips screwed to the upper case. This one appears to be between the battery and the optical drive. You shouldn't need to remove them, they were not removed during the teardown.
MacBook Pro 15" Unibody Mid 2012 Teardown
MacBook Pro 15" Unibody Mid 2012 Görseli
Kılavuz
Zorluk:
Orta
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
MacBook Pro 15" Unibody Mid 2012 Logic Board Görseli
Kılavuz
Zorluk:
Zor
30 minutes - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Kyle Wegner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 309
