Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
Cannot slide to unlock screen
Phone will not unlock, there is no password, it just will not slide to unlock. it wasn't dropped, wet or anything else. My settings are supposed to come up even when screen is locked but that isn't working either.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like a faulty digitizer. Is it responding to your touch at all? If not, you can check the connections, maybe clean them with some isopropyl alcohol on a cotton swab.
If it still doesn't work after that, you'll probably have to replace the digitizer. You can choose between this: iPhone 5c LCD and Digitizer which would require you to switch out the home button and front camera, or you can buy this: iPhone 5c Screen with the home button and front camera included.
Replace a screen compatible with iPhone 5c. Includes all of the small parts preinstalled in the assembly. 4 inch 640 x 1136 pixel LCD Display, Front Glass Digitizer Panel, Front Camera, Earpiece Speaker, LCD Shield Plate. Görseli
Ürün
iPhone 5c Screen
$34.99
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c. Görseli
Ürün
$39.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
First before you take apart the iPhone like its stated below try the simple thing that's most likely to work try a hard reset..
Hold power button and home button together for 7 seconds then let go of home but keep pressing power this will restart and hopefully the touch will work
Puan 2
Yorum Ekle
Yanıtını ekle
Nelia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 432
