Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
My OneNote program keeps shutting down with this error message
"Critical Error:OneNote was unable to save to the notebook cache file for an unknown reason. Possible reasons might include a change in the file permissions or a serious disk error. OneNote will now exit. For further assistance contact technical support. Error Code: 0x17"
Please help me. I tried to run diagnostics and nothing changed, then I tried to update my computer and that didn't help either. I use OneNote for school and this is very inconvenient. Thank you!!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
See next topic: http://myitforum.com/myitforumwp/communi...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The first thing I would recommend attempting is a file system check and permissions repair:
- Reboot the computer in recovery mode
- Start the disk utility
- Select the disk
- On the first aid tab, select repair disk (wait for a long time)
- On the first aid tab, select repair disk permissions
The second thing I would recommend is to manually change the permissions of of your home directory via the terminal:
- Open a terminal and enter the following commands:
whoami
(this returns your username, likely your first and last name without spaces)
cd ~/..
(this changes to one folder above your home folder)
sudo chown -R [username] [username]/
(enter your password when prompted and be sure that you replace [username] with your username, this will ensure you have ownership permissions to everything in your home directory)
Puan 0
Yorum Ekle
Yanıtını ekle
calebprice sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 616
