Ana içeriğe geç
Repair and disassembly guides and support for dish washing appliances.
Should there be any standing water left in the sump?
This is a basic GE dishwasher approx 10 years old (GSD3320C06BB). I was having standing water visible in the tub after finishing (about an inch). I used suggestions offered here in other posts and now it is draining much better. However there is still some water remaining in the sump (I have the sump covers/protectors off). You would not see this water if the covers were in place. Is this normal? I've read elsewhere that some water is supposed to remain so that pump seals don't dry out. Or perhaps I have a check valve in the drain system that isn't functioning correctly. Parts diagrams do not show any check valve so perhaps it would be embedded in the hose or pump itself? Observing the drain cycle, it appears that most of the water is pumped out of the sump as it runs but as soon as the cycle ends, and the pump shuts off, some water flows back into the sump, stopping just before reaching the tub itself. Otherwise the drain flow into the disposal seems to be very strong now. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You were right the first time. If you have standing water below the filters
your fine. That is normal to keep seals
from drying out. Water above filter line is a problem.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
i have old g&e over 10 year if with the cover you can't see the water it is ok.. my dishwasher has water in the pomp to when sametime i do a clean up..
Puan 0
Yorum Ekle
Yanıtını ekle
Joe Majors sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 52
Her zaman: 8,698
