Ana içeriğe geç
Brand Name: Bose Model: 331394-0010
17 Soru Tümünü görüntüle
How toReplace broken speaker for QC25
Hi,
I have a broken QuiteComfort 25 headphone speaker.
No voice at the left speaker.
It needs to be replaced.
However, I could not remove it. I was able to remove the cover the speaker itself does not move and come out.
Also do you know where to find a new speaker to replace the old one?
tHanks,
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
2 Yorum
Are you sure that the speaker is the issue and not the wiring?
tarafından
same problem, ordered new cord, it is the speaker....
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Just called bose they said that qc25 that were made before mid 2015 have had trouble with one ear going out they have fixed the problem and are replacing mine free if it was made before mid 2015 call tech support
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
Hi Jihn.
Dont you have the number you've called?
And how your story ends up? Does they replaced yours QC?
Thanks
tarafından
Was it still under warranty ?
tarafından
Thank you, I am convinced this is the same thing for me as I bought mine early 2015. I am glad Bose is replacing these, because I was worried I flushed $300 down the toilet
tarafından
Yorum Ekle
Hi, I also have this problem, it seems to be a fault with the driver Bose have used, what might work as a temporary fix is to put something like a piece of paper between the black plastic housing and the clear plastic of the driver itself, at the point where the copper wire seperates from the coil to the edge of the driver, it seems putting pressure at this point makes maybe a burned wire make contact. To remove the speaker I took out the two screws holding the second cover in place and then used a hair dryer to heat up the glue holding it in place. I then pryed the black plastic cover off ( if you get a little piece of the glue with a tiny screwdriver you can pull the stringy glue out from all the way around), I did this for the driver underneath aswell. After that I just desoldered the driver and got a replacement off eBay. Hope this helps
Puan 3
Yorum Ekle
I am not sure. That's what the service told me. They cost too much for the new part.
If i can remove it i plan to check the inside cabling.
Puan 0
Yorum Ekle
My QC25 also has this problem。
I have bought a speaker using for QC2.
I want to replace the speaker, but I was able to remove the cover the speaker.
Puan 0
Yorum Ekle
Hello,
I have the same problem but the QC25 left speaker stop suddenly , I'm still in warranty period.
I bought it from amazon what can I do to fix it
Puan 0
Yorum Ekle
good morni ng ,
my left speaker of bose qc25 stoped ,please advice
Puan 0
Yorum Ekle
Mine also has this problem - I just hanged up with Bose customer support.
There was a known manufacturing defect, and an amount of these headphones are affected.
I gave them the serial number, they confirmed, that although the headphone is outside of the warranty period, since it belongs to the defective ones, they replace it with a new one at no cost.
I will get a shipping label, and in 10 days, a new headphones with 1 year warranty.
I needed not to present original packaging or proof of purchase.
Puan 0
Yorum Ekle
I have this problem as well. I called Bose and they offered to send me a new QC35 for $135, but would not offer any sort of free replacement, which was disappointing. But I guess it’s 2018 now and they probably don’t have any QC25s to replace mine with.
I have seen some replacement speakers online, but would like to know the difficulty in replacing them.
Puan 0
1 Yorum:
Was it the QC 35 ii that was offered four $135 Or 35 i ?
Also was the 25 on warranty AND do you have to send back the 25?
tarafından
Yorum Ekle
EASY !!
In most cases, it is the speaker that is the problem !!!
Easy to change:
1. 2 screws inside the earcups and the cloth piece (The earcups are "clips" on plce...use your finger all the way around until you hear click....every 2 cm.....)
2. Use a scalpel to open the cover of the speaker (NB!! warm up a bit first...hair dryer works fine!)
3.Unsolder the speaker and solder a new one !!
EVERYTHING OK !!!
Puan 0
Yorum Ekle
Yanıtını ekle
Koray sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 11,591
