Ana içeriğe geç
Model number TF700T released in July 2012. The Asus Transformer Pad Infinity is a Wi-Fi and Bluetooth capable tablet with a 10.1 inch screen and 8MP camera.
11 Soru Tümünü görüntüle
Trouble getting Ribbon cable back in
I am trying to replace my cracked screen on my Asus TF700T. I can't seem to get the ribbon cables in far enough for the LCD to even work let alone the replacement screen. At first when I turned it on I could see the word ASUS really faintly. I turned the power off and tried to reseat the ribbon but now I can't see anything on the LCD. The LCD worked fine until I took it apart. Is there any trick to being able to slide the ribbon cable back into its connector?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
When you took it out did you notice if the port had a Horz. latch or the end snaps(?).
Make the cable as level and square as you can get and push in all the way. Most of the metallic contacts will be inside the port. It would help if you took Steve Martins advice and got "small" previously.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
dvdmllreorders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 434
