Ana içeriğe geç
iPhone'un ilk modeli. A1203 modeli, 4GB, 8GB, 16GB kapasiteye ve alüminyum arkaya sahiptir. Tamir, kayda değer miktarda kanırtıp açmaya ihtiyaç duyar ve lehimleme gerektirebilir.
224 Soru Tümünü görüntüle
Shuts down, no signal and battery problems only with sim card inserted
I have 3 iPhones with the same symptom. Battery goes down quickly, shuts down or no signal ONLY when you insert de SIM card. I've tested all these 3 iPhones with no SIM card, and they don't shut down, no baterry drain. I've tested with several SIMs cards that work perfectly in other devices (I mean other iPhones)
Bu iyi bir soru mu?
Puan 1
1 Yorum
I also concluded the same. In my case it seem batteries got faulty as I moved to 110V country from 220V and used a voltage transformer in front of adapter to charge the phone. It did something bad with the batteries. Though phone works fine when on charging. It shuts down only when I try to place a call. Thanks for this ans
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
in my opinion - there are 2 possible problems (if fluid damages are ruled out in the first place)
1, the batteries are extremely weak - as soon as the phone uses the mobile phone part - the battery crashes
2, the Skyworks GSM/Edge Power amplifier (SKY77340) is faulty
(top right on the picture)
i use an infra red thermometer to find those faulty parts
but as i said, those two things are pretty common failures on other phones
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
+ good answer. I couldn't find anything for those bizarre symptoms.
tarafından
tarafından
really good answer. I don know about this infra red thermometer, and it seems to be a useful tool. Where I can found it, and how do I use it?
tarafından
²majesty - i worked as technician in a nokia store and was self employed for years in that business. ²macpatagon - search ebay for infrared thermometer - but you can use the cheapest one for 2 or 3$ - it's not important to have the exact temperature - important is the difference. using it is simple, press a button and hold it directly over the parts - if you hold it over every area of the board - you can find faulty ic's extremely fast
tarafından
@ Markus: I can see that. You have to have hands on experience to troubleshoot bizarre cases like this one.
tarafından
Yorum Ekle
I am having the same problem with all the nokia phones I have, with one particular sim. Even with those phones that work fine with other sims. - Help!
Puan 0
1 Yorum:
the sim most likely is faulty or simply incompatible with your phones
tarafından
Yorum Ekle
Yanıtını ekle
Flavio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 6,339
