How to Fix no Power
How to Fix no Power...i dont know how to fix this...
Bu iyi bir soru mu?
Check the wires and contact of the batteries. If all are good. Check polarity of batteries. If all is good. A tiny line of the circuit board is burnt because you put the batteries in a wrong way And there is no fuse.
Bu yanıt yardımcı oldu mu?
If there is burnt bit in the circuit board and no fuse what can I do to fix this problem?
To fix the burn in the circuit board you have to have a soldering gun, flux paste, tin- lead and good soldering skills. To repair , first you have to find the area that has the open circuit, then remove the green material that protects the cooper for corrosion. Put a bit of flux paste on the expossed part of the circuit that we previously peel. Then solder the area putting a bit of tin-lead. Find a piece of wire (small caliber..18-24 gauge)to make a bridge in the 2 areas.
I had a similar problem. The camera would power on, and I would even get a couple of pictures, the it would shut off and could not be turned back on.
Long story short. It turned out that I was using rechargable lithium batteries and the camera was expecting alkaline. I gather there is a different power profile.
I updated the settings and have not had another problem.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 2,612
It looks like I have some corrosion in one of the battery chambers of my camera, is there and way of sorting this and repairing??
becky donald tarafından Paylaş
