Ana içeriğe geç
Renault Mégane II olarak da bilinen 2. nesil Renault Mégane için tamir kılavuzları ve destek.
How to replace the timing belt
how to timing the car?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
1 Yorum
Hi, my 2004 renault megane is making a grrrr sound when idling and driving.
My belt has alota fine cracks. What can be the problem?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Oh dear you need the special can locking kit with the tdc locking pins ,Reno's are a ##&&% to work on I know I got a modus 1.6 its the same set up ,they also use a dephaser cam gear so if it starts to make a rattling sound on start up get it changed , only use synthetic oil and change the filter twice a year because they are so small , buy a can of silicon spray and spray every electrical connection and fuse box ,these things are prone to damp ,
Hope it helps you ,good luck !
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
There is a perfect book for repairing this car on your own. Give it a try
https://haynes.com/en-gb/renault-megane-...
Puan 0
Yorum Ekle
I changed the timing belt a few years ago. I didn't use any locking kit. The hole to lock it is inaccessible. It looks possible in the Haynes book but it isn't. I marked up everything with a white pen and took the chance of nothing moving. It worked fine and I saved 500£/€\$. I took my time when I didn't need the car.
Puan 0
4 Yorum:
You cannot do this with the diesel engine variants without running a real risk of the camshaft moving relative to the camshaft Marking the parts simply doesn't work as the crankshaft pulley is not keyed the the crankshaft on the diesels.
tarafından
@cjrc your diesel has a timing belt? What engine is this exactly?
tarafından
@cjrc Awesome and I just found the tools for it as well. I thought it was uncommon for a Diesel to have a belt vs a chain but I guess Nissan/Renault built a pretty good engine with it.
tarafından
Yorum Ekle
Yanıtını ekle
reza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 60
Her zaman: 12,900
