Ana içeriğe geç
An HP desktop computer released in 2008.
Hard drive is full of virus. How do I fix it?
Hard drive is full of virus. How do i fix it
Bu iyi bir soru mu?
Puan 7
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're missing a lot of detail in your question, but I'll assume you're at least running one of the last 2-3 major releases of Windows. I'll also assume you've correctly identified viruses as the cause of your trouble, rather than hard drive or memory issues.
You're going to need to download and Install a program called MalwareBytes. You may need to use another computer to download the software, then transfer it to the machine you're going to work on with a USB stick/thumb drive (or equivalent).
If you can't boot up into Windows normally, try booting into Safe Mode with Networking.
Once installed, launch MalwareBytes and allow it to scan your PC. I recommend allowing it to remove pretty much anything it finds and flags for your attention. If it does find anything, re-run the scan again after you've allowed it to remove the infections. Repeat until your scan comes up clean. After that, reboot the machine (into normal Windows mode, as opposed to safe mode) and see if everything is better.
Bu yanıt yardımcı oldu mu?
Puan 6
Yorum Ekle
I have an old hp 6700 model and keep getting an error message : windows error recovery screen message. I do not hav the original recovery disk but is that what I may need?
Puan 0
1 Yorum:
@b7664 what is the exact error your getting is it blue screen and is there an error code you can forward to us. Also what windows version are you using ?
tarafından
Yorum Ekle
Reset computer back to factory defaults.
Re-install antivirus software and update.
Re-apply all updates. Windows and all other application.
Avoid viruses in future! :-)
Puan 0
Yorum Ekle
My screen is full black
Puan 0
Yorum Ekle
Yanıtını ekle
dscott22 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,839
