Ana içeriğe geç
PlayStation 3 Slim, orijinal model numarası CECH-2000 olan PS3 video oyun konsolunun ikinci sürümüdür. Sony Computer Entertainment tarafından üretilmiştir ve orijinal (Fat) Playstation 3'ün birçok sorununu gidermiştir. Ürün 1 Eylül 2009 tarihinde piyasaya sürülmüştür.
465 Soru Tümünü görüntüle
Why won't my PS3 stay on
My PS3 won't stay on. I was playing assassins creed 2 & it froze. I turned it off & turned it on again but now it won't boot up properly. I tried the reset by holding it down for 10 seconds but instead of the beeps I'm supposed to get, it just powers off & if I leave it on without holding down power button, it turns off after about 30 seconds
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This type of behavior is usually caused (at least initially) by heat. After a while, the heat compound on the CPU breaks down and is not able to transfer the heat from the CPU to the heatsink properly. This leads ultimately to overheating. Once this happens, all bets are off. Most likely, the CPU overheats right away which is why the system shuts down. Start by replacing the heatsink compound and to run the system again.
Let us know how you make out...
Dan
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Same problem here. Did y'all find a solution?
Puan 0
Yorum Ekle
I believe that it may be a power-supply problem, which causes it to lose power after a few seconds when the HDD activates.
Puan 0
Yorum Ekle
Yanıtını ekle
stephenmurphy28 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 651
