Ana içeriğe geç
The GoPro Hero3Plus Black Edition can be identified by its model number: CHDHX-302. It's an eighth generation camera that was released in October 2013. The GoPro Hero3Plus Black Edition is a Wi-Fi capable, 4K resolution digital camcorder.
HDMI port has caved in. How do I fix it?
My HDMI port broke and needs to be repaired. I'm not sure if I am going to have to solder the connections or just use some crazy glue. Im scared, actually terrified of tearing it down then realizing that I cant fix it with my limited knowledge of and experience with soldering very small connections, and etc. Anyone that can give me any advice at all concerning this would be greatly appreciated.
Thank You
mishmael
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There is a take apart video of a fellow that had the same problem with the USB connector. When his disassemble his cam and got to it, the pads were lifted from the motherboard and because of the compactness of it, there is no way to repair that. A new mobo will solve the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Mobo ? What's a Mobo ?
tarafından
motherboartd
tarafından
Oh ok I'm not sure if I am going to replace the entire motherboard that sounds expensive
tarafından
Yorum Ekle
mishmael, remove the logic board by using this guide. That is the easy part, the hard part will be to source the port and find somebody that can microsolder. I'd try places like Digikey or Mouser to try and find a replacement. There is plenty of space to solder for the right person. No you cannot use crazy glue. If you want to go and replace the motherboard, it is available right here
Main circuit board assembly for the Black Edition of the GoPro Hero3 Görseli
Ürün
GoPro Hero3 Black Motherboard
$19.99
Puan 2
2 Yorum:
The parts are fine the port is in great shape just need to micro solder but I'm also terrified of opening it up
tarafından
mishmael254 got to start somewhere to repair it. If you do not think you can do it, check some of the numerous GoPro repair service centers online.
tarafından
Yorum Ekle
Yanıtını ekle
mishmael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 4,110
