Replacement of hard drive with larger capacity cause issues?
Hello! I need to replace the HD in my iBook G4 12" 1.2GHz 30GB HD. I'm looking at buying your IF107-069-1 (320 GB 5400 RPM Western Digital ATA Hard Drive). If I replace my HD with a larger capacity HD will I loose any functionality?
Also, is there a larger or faster RPM HD for sale for this model? The reason I ask is because I once tried to replace the HD in a G3 iMac with a non-approved HD and that iMac would no longer go to sleep.
Bu iyi bir soru mu?
Colleen, thank you for the prompt response!
Stafford tarafından
If Colleen's answer helped you, you should accept the answer. If you're still not sure of a resolution, at least vote her post up.
Kyle Wiens tarafından
