Ana içeriğe geç
HTC One'ın ikinci nesli olan HTC One (M8), çift flaş ve yeni Sense 6 arayüzüne (UI) sahiptir; 25 Mart 2014 tarihinde piyasaya sürülmüştür.
Power button not working.
Hi, my girls phone recently started doing this weird thing where it appears that the power button is being pressed down even though the button isn't being press or stuck in the pressed position. I order a replacement part, the daughter board that has the power button on it and after I did it appeared to be working correctly. Then about a day or so later the power button stopped working all together. Not sure what the issue might be other than a bad part but I find it strange that it was working and then just went out all together.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
1 Yorum
Same thing happened to me but it started after a phone call right after I got off of the phone I was going to try wiping it completely to see if that works it definitely has to be something in the programming because the phone didn't get damaged
tarafından Paylaş
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Get cocoa butter or like kind of a grease on your fingers and attempt to access apps and do regular things on your phone and it'll stop it'll do it every now and then but rarely. Also there's the power off apps if that doesn't work
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The only prob here is just the replacement but i advice u to send to some phone service
Puan 0
1 Yorum:
Its all about power button
tarafından Paylaş
Yorum Ekle
on off battun not werke
Puan 0
Yorum Ekle
There are multiple ways you can replicate the functionality of your power button in case yours doesn’t work anymore. Here I will tell you about the only two methods, excluding the obvious other one – having it repaired: turning your phone on and off with the help of apps and a neat little piece of hardware to help you do the same.
Puan 0
1 Yorum:
Well, tell us then ...
tarafından Paylaş
Yorum Ekle
power key not working??
Puan 0
Yorum Ekle
Yanıtını ekle
cdude78411 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 21,957
