Ana içeriğe geç
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Soru Tümünü görüntüle
Soru Kapandı
Do I remove the protective cover removed?
In step 37 B you show that you are raising the red protective cover from the display. Is this required? I am repairing an IPhone 4 CDMA and the red cover is still on there. Please help soon.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, remove the protective cover on the back of the new LCD assembly.
WARNING: Failure to remove the protective cover from the mirrored back of the display assembly will damage the LCD. There is a thermal pad installed on the iPhone frame that absorbs the heat from the LCD and disperses it though the frame, preventing the LCD from
overheating.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you for the helpful info. I have now replaced two front displays and removed the transparent protective cover.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 80
