Ana içeriğe geç
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 Soru Tümünü görüntüle
Why is my screen red?
When I'm watching something on tv my screen is red in places that should be black or just in places that should have a dark color and I don't know how to fix this please help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
5 Yorum
It's playing but it's red screen
tarafından
Thanks for this. I know you may never see it, but just thought you should know your comment helped me out.
tarafından
How to fix my tv when it go different colors
tarafından
someone please help me im only 11 so none of these are helpful and the one that was did not work for me
tarafından
@iDoit4LoLz we get emails on our posts and glad it worked! I have used the 24" Vizio screens for monitors and right now am using about 12 of them.
Two of them have had this issue and only needed the power button routine once... since 2018.
We have dropped or knocked them on the floor and they are pretty durable (except the screens of course). Thanks and best of luck!
tarafından
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
try doing this go to https://www.youtube.com/watch?v=84tyJ6A1...
have a good day.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I received a new tv I had purchased through Walmart and red was where the black should be... read all the blogs about power sources and light modules...so called Vizio and the rep told me to unplug it for a bit, then hold on the power button for five seconds and then plug it back it - and worked like a charm for me.
Not all fixes will be this easy - but it worked for me and thanks Vizio Tech Support :)
Puan 3
3 Yorum:
We have an LG TV and unplugging and holding the power button down 5 seconds and plugging back in worked! Thanks so much!!!
tarafından
Thank You!! I just purchased my 24 inch smart TV from Vizio and was having the same color problem as red was showing for black and pink was showing for blue...did this trick and it worked!! Thank you!! Saved me from buying a whole other TV ♡
tarafından
why wont it work for me
tarafından
Yorum Ekle
https://youtu.be/0wZZj93bFa0
Puan 2
2 Yorum:
As I stated in another comment, THIS was the only thing that fixed my TV, THANKS alot man, may God pay you back!
tarafından
But what was he doing with the tweezers to the wire in it? I didn't understand that part
tarafından
Yorum Ekle
Show to tv engineer..He will replace the color IC chip ..It cost you around 3000
Puan 1
3 Yorum:
Go for the first reply's option if your dealing w a tv that wont turn on or you have a pink screen but for this posts problem try this vid though i have to thank the first replyer cause it was his link that lead me to find this vid which fixed my tv
tarafından
T conn board 20 bucks on eBay
tarafından
David Ramirez's Comment helped me, I opened the TV, move the cable a bit and it worked like a charm. 8 years old Vizio TV still giving it all like the first day! LOVE this 22 inches Smart TV!
tarafından
Yorum Ekle
Replace T-conn board 20 dollar fix. You can get the part on ebay.
Puan 1
Yorum Ekle
I am having the same problem... My smart tv is just two days old.... I restarted it and it started working fine…. But I'm worried if it happens again
Puan 1
Yorum Ekle
My screen is red with black lines in it what is it and how mutch
Puan 1
1 Yorum:
Mine too, has sound, red screen with black lines
tarafından
Yorum Ekle
Puan 0
1 Yorum:
I posted this above several years ago, but this is not a fix all for the red issues for all Vizio (and some other brands made with the same components. A chip may need to be replaced as posted above as well. For the 11 year old if the power button does not work, you will need a TV repair person.
Keep in mind the cost of the fix may be more expensive than buying a new set unfortunately. Right now Walmart has on online price of $99 for a Vizio 24" to pick up in the store.
While you may be able to pick up a chip on eBay for a smaller amount, you may be purchasing a used or part which will not work.
Electronic components does take some knowledge so it is not dangerous, since these are electrical parts.
If you have an adult who is trustworthy and knowledgeable may be able to help you. My sons learned a lot of electronics through the Boy Scouts, because some of the leaders worked for Collins, which provides for the space program (and others).
Hope that helps and good luck!
tarafından
Yorum Ekle
Change your T-con board (control board)
Puan 0
Yorum Ekle
Yanıtını ekle
Casey Perez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 59
Son 30 gün: 214
Her zaman: 75,987
