Ana içeriğe geç
Moto G2 olarak da bilinen Motorola Moto G (2. Nesil), 2014 yılında Moto G'nin halefi olarak piyasaya sürülmüştür. Moto G2, 5 inç 720p ekran ve Qualcomm Snapdragon 400 işlemci ile donatılmıştır. Model numaraları XT1045, XT1040, XT1039, XT1069, XT1068 ve XT1064'tür.
Bottom Speakers not working.
In the recently hit earthquake in our country Nepal, my Moto G 20014 (XT1064) fell of my shelf but no damage was seen in the screen. However, later I noticed reduced speaker sound, specifically the bottom one. Then I found that the speaker was not working at all. However, if I gently hit the backside of the phone where the bottom speakers are located, it gave me output for a while and then again stopped working. I tried a couple of times and it worked most of the times. So i think the connection of the speaker has loosen and i was hoping if your team could help me fix/repair the loose cable connection.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi,
You need to remove the back cover and then remove the first covering of the phone.
After that you can try removing the speaker located at bottom right.
Speakers are rectangle shaped and black in color.
Clean them and check if contact pins are misplaced.
after that place them correctly and attach the covering.
Check if it works.
Please note that you dont need to dissemble your phone, just open the second covering with screw driver and you can see the speakers or use any iron and look for magnet at bottom.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I have a similar problem. I replaced the battery. Now, my speakers don't work. At first, it was the bottom so. Now the top one doesn't work.
Puan 0
Yorum Ekle
Yanıtını ekle
ssanjysh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 5,643
