Ana içeriğe geç
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 Soru Tümünü görüntüle
Flash and Front/Back Camera not working
I have a Sony Xperia Z3 here and after a screen replacement the front and back camera no longer work as well as the flash. When I plug the rear camera in the phone overheats a lot! Any ideas on how to fix this would be appreciated! Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
7 Yorum
Any updates?? Currently have this issue and can't seem to work out why it is happening. Going to try a new screen on the phone just to retrace every step but if anyone knows anything that'd be pretty helpful.
tarafından
Any fix i having this problem right now help please :/
tarafından
Same problem. help please
tarafından
Did you find the solution to the problem? As much as I've understood, it has to be the flash. Before I broke my phone, I sometimes had flashlight working in some other app and then when I tried to start the camera app the error appeared "Unfortunately camera has stopped".
Did you do something to fix the problem, or had to replace the motherboard?
tarafından
Hey, I've the same problem. I don't know how can I fix it, but a friend told me that he has resolved it just by changing the rear camera. I still doubt but I'll try. I can't see any link between the camera and the flash light.
Is there anyone else has tried to repair it himself?
tarafından
2 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I'm having A- Z same problem .. After replacing my z3 screen , back camera front camera and flash not working anymore.. Also flashlight toggle disappeared from home screen .. I think problem is related to flashlight . When I connect my back camera the phone heats up and battery drains by 1 % every 2 minutes ..But when back camera is removed battery drains by 1 % every 2 hours ..
I tried every thing from factory reset , repairing through sony pc companion , tried other camera apps , changed camera sensor etc .. I came into point there is some short near camera or problem is due to flash (As flash light is also not working and flash toggle has disappeard from home screen .
Also please note on diagonistic front camera shows up but back camera doesnot shows up .. In camera app when clicked I get a message " Unfortunated camera has stopped " .
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
You could fix?
tarafından
Yorum Ekle
I send the mobile to repair shop and he solved this problem by change the camera ic
Puan 1
4 Yorum:
How much it cost??
tarafından
is there a way to fix that camera ic by myself? On iphone 6 to fix camera problems just need to make jumper on ic.
tarafından
Bro explain how to fix it??
tarafından
As i understand then these smd resistors we need to repair. Am i right?
https://i.imgsafe.org/7c7544f09b.jpg
tarafından
Yorum Ekle
Try another front and back camera. Not sure how you're having this overheating issue as I've replaced around 10 Sony Xperia Z3 screens.
Did you put in the plastic mounting bracket for the Back camera? Including the metal mounting bracket which is held by the housing frame of the phone?
Puan 0
Yorum Ekle
This may be a camera application cache problem.
Clear the Camera cache in the settings>Application>camera. Then Clear the whole Application Cache in Settings>Storage and memory>internal memory>(swipe down to) Clear the shared application memory (or smthg like that).
If clear the camera cache cannot solve the problem, you can try reconnect the camera flex cable, cause the flex cable maybe loosen when accidentally drop or hit.
This Sony Xperia Z3 Teardown can help you disassemble it.
Puan 0
Yorum Ekle
Yanıtını ekle
William sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 8,021
