Picks up a second sheet of paper and jams
The printer regularly picks up a second sheet of paper which causes a jam. I have fitted a new roller which doesn't help at all and cleaned everything visible. This happens both with the bottom feeder tray and the manual sheet feeder. It's getting worse, so that now it even does it on a single page job. Printer has done a total of 10k pages and 500 odd on the current cartridge.
Bu iyi bir soru mu?
4 Yorum
I'm having the same issue. It seems as if the printer doesn't recognize that a piece of paper has been picked up and continues to repeatedly actuate the roller mechanism. I don't know enough about this model be certain.
Kile tarafından
I am having the same problem I guess. When it prints the printed copy is no fullly released from the printer and another sheet has been partially picked up and then everything starts and I get the alarm. I put the sheets out and open and close the top door and then it is ready to go again.
Seward Ford tarafından
It the pick up solenoid. It has two rubbery pads that go sticky, and it can get stuck either opened or closed. Repair is easy (remove the sticky pad and put a piece of thick tape or foam), but accessing the solenoid can be a pain. On the 2525w it's on the left side of the machine. You have to remove the left cover (which implies removing the rear and top cover first), then the motor plate.
Curious Marc tarafından
Thanks. I had the same issue on my Samsung 2525w and putting tape on the solenoid fixed the problem.
David B. tarafından
