Ana içeriğe geç
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40 Soru Tümünü görüntüle
I have antifreeze coming form the exhaust
I have a 1997 jeep cherokee sport. It was over -heating due to a cracked radiator..So I replaced the radiator and still overheating. I than took off the thermostate and now I have antifreeze coming form the exhaust...HELP what is this...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
why do you think it is anti-freeze?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
In best case you have just blown head gasket... In worst cracked engine block or head.....
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Look at you're oil cap ware you put oil in and If you see like a frothy look to it you probably have a bad head gasket you can also look at the dipstick and if its higher than what its supposed to be you probably have a head gasket problem. If it is a head gasket when you take the head off take a really straight and flat peace of meateal and go slowly across the head in all directions and if you see any gaps even a little one take it to a machine shop and have them shave the head otherwise if you just put a new gasket on it will still leak also look for cracks . You could have them preasher test it as well it should all cost about 60 or so.
Puan 1
Yorum Ekle
Yanıtını ekle
smilez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 237
