Ana içeriğe geç
Samsung'un Asya pazarı için geliştirdiği, birçok model numarasıyla bilinen ve Aralık 2014'te piyasaya sürülen bir Android akıllı telefon. SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W modellerini içerir.
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Bu iyi bir soru mu?
Puan 21
28 Yorum
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
tarafından
That was a fantastic clue. works perfect!. Thank You Dude.
tarafından
Wow that really helped me thank you very much
tarafından
worked perfectly. thanks much!!!
tarafından
Amazing advice! Nothing else worked but this did. Thank you :)
tarafından
23 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
Bu yanıt yardımcı oldu mu?
Puan 33
21 Yorum:
Dat was really helpful. ..thanks!
tarafından
its working thank you so much
tarafından
its good idea..... thank u .....
tarafından
good job...... i really like u......
tarafından
it's work... thanks
tarafından
16 tane daha yorum göster
Yorum Ekle
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Puan 3
2 Yorum:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
tarafından
Many, many thanks
tarafından
Yorum Ekle
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Puan 0
Yorum Ekle
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
Puan 0
1 Yorum:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
tarafından
Yorum Ekle
Yanıtını ekle
Billy495 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 60,613
