Ana içeriğe geç
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Play station 3 controller not charging nor connecting
My PS3 sixaxis dual shock controller is not charging nor connecting to my slim console. When I press the ps button the four lights start blinking but eventually stop with no connection,even when I connect the usb charger,nothing happens..I've tried resetting it using the small hole at the back but still nothing has changed.. Please HELP!!!!!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's sounds to me like the USB port itself is broken.
Have you tried a different cable? Have you tried charging it through a PC?
If neither worked, then it is more than likely damage to the USB port in the controller, you can repair it with the right soldering skills, if not, it's probably easier and cheap enough to get another controller. :)
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for your response.. I have two cables both don't work for the controller.. But one of the cables shows a response on the screen when connected ... It's says "the maximum power that can be supplied has been reached,please remove one connection "
tarafından
It's more than likely the port itself on the controller is damaged, it is probably cheaper and a lot easier to get another controller.
Saying that, this is iFixit, and if you know how to solder, you can just replace the USB port itself! :-)
tarafından
Yorum Ekle
Yanıtını ekle
remmysichinga sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 804
