Ana içeriğe geç
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
Why my calculator is not charging?
When I plugged in the charger, it shows greenlight but still low battery even though I charge it overnight
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
9 Yorum
I read on another site that if you unscrew the battery compartment, unwrinkle the cords, it will charge better. I didn't think that would work, but strangely enough, it is charging and actually working. Hope this helps.
tarafından
how do you open the battery compartment though? mine wont open
tarafından
Sarah Durbin you checked this guide?
tarafından
This worked for one of my students. Thanks for the suggestion!
tarafından
but what if you have the one that is color and doesn't run on batteries
tarafından
4 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try using the reset button on the back. That fixed it for me!
Bu yanıt yardımcı oldu mu?
Puan 5
6 Yorum:
It worked for me as well!
tarafından
reset button on the back meaning?
tarafından
Using the reset button on the back worked for me too.
tarafından
Where is the reset button?
tarafından
It doesn't work at all...
tarafından
1 tane daha yorum göster
Yorum Ekle
Puan 2
1 Yorum:
It worked! thank you :)
tarafından
Yorum Ekle
Reset your calculator: If you turn to the back of your calculator in the mid-left you will see a small button that says reset.
  • Using a pen (pointy) push it and turn on the calculator again.
If this method doesn't work for you then you might have some other problem.
Puan 0
Yorum Ekle
If your graphing calculator isn't charging and it doesn't take 4 AAA batteries then it works on a block battery that you have to unscrew the 2 screws and unplug it for 10 seconds, plug it back in and tighten the 2 screws and charge it and it will function normally.
Puan 0
Yorum Ekle
Your calculator battery may be reduced in lifespan and it could also be your charging port. You can buy charging ports for TIs and other brand calculator online.
Puan 0
Yorum Ekle
Yanıtını ekle
faroukiskandar96 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 72,132
