Ana içeriğe geç
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Soru Tümünü görüntüle
Soru Kapandı
Why is the magnet end failing to stay connected?
The magnet end of my MagSafe Adapter has stopped connecting consistently. I've cleaned out the socket (had a small metal bit get in the way once a couple of years ago) but this time no luck.
There seems to be quite a bit of play in it now, an older 2.66 GHz Intel Core i7 15" MBP.
Does the socket sometimes wear? or the pins start to loosen? or.... ??
And is there a fix?
Thanks for any help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
To find out if it is your plug or the socket, see if you can borrow a friend's MagSafe. If theirs works, you need a new cable. If it doesn't, it is your socket and you can narrow down what the problem is from there.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Ah, great thought on a differential diagnosis, like the docs say. Thanks, Jay, I can get at a second MagSafe tomorrow and will see what happens and report back.
Not sure which I'd prefer, though I guess getting a new MagSafe would be easier than figuring out how to fix the socket.... didn't see anything on that in a search here on iFixit... :}
tarafından
Yorum Ekle
The magnet are on the dc-in board in your computer, the magnet doesn't wear out over time. is the metal piece still attached to the end of your charger? sound like you need a new charger.
Puan 0
2 Yorum:
Thanks, Sunny. The magnet is still there for sure, and feels strong. Somehow the connection inside is what's gotten flaky. Have you ever run into the pins loosening, for example?
tarafından
i cant say i have the charging circuit is build really strong. i guess it can happen. if you can take videos or pictures i will have a better idea what you are deal with.
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 152
