Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Screw Size and Diagram
Hiya Everyone,
Hopefully someone will be able to help, basically I accidently knock my screws of my magnet board when repair my iPhone 5s. So now I don't know which screw goes where does anyone have a diagram that states the size of the screw or any advice on what to do
Thank you all.
Update
thank you guys, appreciate the help.
I have one other question I have a little rubber square and I'm not quite sure where its come out from and can not see it on the guide any ideas?
Thank you in advance
Bu iyi bir soru mu?
Puan 3
1 Yorum
This rubber square comed from the microphone hole on the lower part of the phone. It's internal and protect the microphone from the dust.
https://images-na.ssl-images-amazon.com/...
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Sam,
Are you following an iFixit guide?
If not, go to that page, choose the guide that you need, and you will see that there are steps that indicate what screws go where, and their respective sizes. You will need an accurate measuring tool such as this caliper to measure the length, and trace each screw back to it's original place in the phone.
The most important screws to watch out for are those that hold the shield covering the screen connectors.
If in doubt, don't put any there. If you use a screw that's too long, it will rip through the board, potentially breaking traces within the board and causing very expensive damage.
Digital Caliper Görseli
Ürün
Digital Caliper
$39.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It's the rubber for the mic. Goes between the headphone jack and the charge dock.
Puan 1
Yorum Ekle
That little rubber square goes at the bottom of the iPhone it holds a flat ribbon in place but it is not absolutely necessary
Puan 1
Yorum Ekle
Sam, the individual guides on here list the screw size with each step.
Puan 0
Yorum Ekle
Yanıtını ekle
Sam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 20,972
