Ana içeriğe geç
eMac, eğitim pazarı için tasarlanmış ve Nisan 2002'de piyasaya sürülmüş, G4 tabanlı hepsi bir arada bir Mac bilgisayardır. CRT ekran kullanan son Mac modeli olup okullara ve diğer kurumlara düşük bir fiyatla satılmıştır.
Am I using the wrong ethernet cable?
when using an average ethernet cable,emac
won't recognize it.
Will the Belkin RJ45 FastCAT™ 5e Patch Cable, Snagless Molded Cable fix my problem?
Also, is there a way to upgrade the 1.1 usb ports with 2.0 usb?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
First thing you should do is just try any other ethernet cable, to rule out a bad cable. Ether cables are fairly delicate and shouldn't be bent too sharply. Are you seeing "No cable connected" in the Network control panel? If you still get this message with a different, known-good cable, then your Ether port might be toast, but first you should try zapping the PRAM, resetting the NVRAM, and booting to a different system, to rule out software.
If your port appears to have died (I've had this happen a few times) you can get a USB-Ethernet adapter like this one: http://eshop.macsales.com/item/Macally/A...
Of course, first check ifixit to see if they have something like it!
Zap PRAM: reboot while holding down command, option, P, R. Keep holding down till you hear 3 chimes.
Reset NVRAM: hold down command, option, the letter O, and F. You'll get a while screen with black text. Type "reset-nvram" and Return. Type "reset-all" at which point the computer will reboot automatically.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
NO and
NO
Re the cable, what are you connecting to, you may need a crossover cable?
Puan -1
5 Yorum:
Macs since a long time back don't need crossover cables; they can sense what's needed and deal with it internally.
tarafından
A cross-over cable would be used to connect like devices (eg. 2 hosts, a desktop to a laptop). Straight-through cables are used to connect different devices, such as a host to a router.
You may want to check up on your answers before posting.
tarafından
Many recent Macs, including all Intel Macs, do not require crossover cables. See http://support.apple.com/kb/HT2274. As for this eMac, if it's ATI graphics or later, it does not require a crossover cable; they have Auto-MDIX, which automatically configures the ethernet connection. The OP does not say what they are trying to connect to, as you correctly point out, but one can presume it's a hub, switch, or router, as that's the most common scenario.
tarafından
Still, the probably scenario (unlike devices), a straight through, the most common type of ethernet cable, is the needed one.
tarafından
AKA a patch cable.
tarafından
Yorum Ekle
Yanıtını ekle
Celeste sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,925
