Ana içeriğe geç
The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
48 Soru Tümünü görüntüle
need replacement fan, behind modem, ethernet etc
I need a new fan, but I don't know the part number (or where I can get one) - or what this particular fan is called so I can order a new one? I looked at the teardown and by removing the two screws next to the ethernet, usb, firewire etc., ports on the back I can remove and replace my now very noisy fan which is on the other side - it just started getting noisy a week ago. Thank you! jon
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're probably talking about fan part number 922-3295
Here's a parts teardown: http://ep.yimg.com/ca/I/lovemacs_2113_43...
Here's links to the part:
http://www.allmac.com/shop/product_info....
http://www.mac-pro.com/s.nl/it.A/id.2239...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
tarafından
Yorum Ekle
hmm, actually I don't think that's it - this chart is really cool, but it's showing an earlier G4, not the Quicksilver - and the fan doesn't look correct. Mine has a chunky black case. But thanks for the effort. jon
Puan 0
2 Comments:
there were two versions of the 733. Both used the same fan. See if this looks right: http://ep.yimg.com/ca/I/lovemacs_2114_10...
tarafından
I ended up ordering cpu fan #2410ML-04W-B47 off of ebay, It looks to be the right fan and it was only $10. Thanks - jon
tarafından
Yorum Ekle
Yanıtını ekle
jon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 944
