Ana içeriğe geç
Repair guides and support for smartphones in the Curve line produced by BlackBerry since 2007.
My BlackBerry Curve 9320 phone is not getting started...
my phone is not geeting started after software upgrdation ...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
I had the same issue and fixed it with a hairdryer! Try taking out the battery, blow drying it for a little while on all sides. Then blow dry the keys of the phone and inside where the battery goes. I don't know why it worked but it did. I assume there was either dust blocking connections, or some moisture causing issues.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
hello Hari Saladi ,
it is very easy to fix your phone. case is the firmware not update properly
Use this line to download JL commander
  • install jl commander
  • connect your blackberry to pc via USB cable
  • select option 5 (reset to factory defaults)
  • your phone will be restart and hangs with error on white screen
  • install blackberry desktop manager using this link
  • update software gain
after updating the software you can use your blackberry with better performance ever !
Puan 0
Yorum Ekle
Yanıtını ekle
Hari Saladi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 464
