Windows server 2003 audio and wifi drivers are not install
hi i install windows 2003 server edition in my laptop in that audio and wifi drivers r not installed plz any one help me
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi, I can only give you general advice since I don't know the make and model your laptop. If you purchased the laptop new you should have received a disk with drivers for that model. If you don't have the disk go online to the maker of your laptop and download the current drivers from them. Another possibility would be to go to the makers of the sound card and wifi card and download from them. If you don't have that information download and run Belarc Advisor. This is a Windows program similar to Apples System Profiler. I'll include a link to the program. Good luck Ralph
Bu yanıt yardımcı oldu mu?
if the drivers for a device are not installed during the setup process, windows simply don't have the drivers.
you need to use the drivers from the manufacturer of the notebook
if they don't have any - try to locate the drivers with your preferred search engine.
if you don't know whats inside your computer, use a tool like "unknown device identifier"
Hi would like my suggistion is first we can identify the drivers are installed properly or not.May be the drivers are not installed just check ur laptop model and goto the that website and dowmload the proper drivers for that,else just simply install Drivers Pack Solutions Software.The entire drivers are contain ok.
links: dell: www.dell.com/support/drivers/in/en/inbsd
lenovo: support.lenovo.com
hp : support.hp.com/us-en/drivers/
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,447
