Ana içeriğe geç
Released in 2010, the Flip Mino HD is a pocket-sized camcorder with 4 GB and one hour of shooting capacity.
Replace Mino HD Battery
I wanted to replace MinoHD battery. Can I do this?
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can definitely change out the battery although its clear the mfg would rather you buy a new flip for $165.00.
Remove the cover very slowly and carefully so you don't break the ribbon cable. You can then unplug one end of the cable and leave it in the socket on the other end. Carefully fold over the display and be careful because the mylar backing is glued down. After folding it over, you can access two of the four screws that hold down the circut board.
You don't need to remove the two screws holding the USB flip connector.
Remove the battery following the ifixit procedure but be careful not to break the tiny power wires at the top of the circut board. Only slightly elevate the bottom of the board and, after unscrewing the metal battery carrier and carefully unplugging the battery connector, you can pop out the battery. You will need to use a long thin knife to carefully pry the battery from its carrier as it is glued in place w/ sticky tape.
Go to Batteries Plus and get the battery and replace it following reverse procedure.
There you have it :)
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
how to open and replace battery?
tarafından
having a problem opening flip mino hd i have one scew out other is not budging
tarafından
Having the proper tool makes a difference. Someone said larger handles = more torque, Screw Extractor may also be a solution.
tarafından
FYI, the ribbon cable is at the bottom.
tarafından
Yorum Ekle
Hi All
There is a simple question ? Sorry..
Whre can I buy this kind of Battery , Mini HD Rechargeable Li-on Battery
Model No. 1UF553450-1-T0423.
3.7V 1150mAH
Thanks in advance
Bernd Sommer
Puan 0
Yorum Ekle
try ebay for the battery
Puan 0
Yorum Ekle
YOu can try bestbattery.biz flip mino hd battery
Puan 0
Yorum Ekle
Yanıtını ekle
Bunts sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 18,206
