Ana içeriğe geç
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797 Soru Tümünü görüntüle
How do I replace my charging port?
I got the part but have not found the guide on ifix it, can you help?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
1 Yorum
I need to know too. Is there a battery that can be changed? wont hold charge
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
LaRivieresr, does not look like there is one specifically for the charging port. Try this video and see if it works for you. While you are replacing the charging port, take lots of pictures and make a guide for the rest of us.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
We have a Kindle Fire that isn't accepting a charge. Is that the connector or is it the battery? Where would you get it fixed?
Puan 0
Yorum Ekle
Apparently charge port on these Amazon fire tablets are notorious for coming loose and/or disconnecting from the tablet. Usually a solder joint breaks. We got 1 for each of our 5 yr. old granddaughter & both won't charge after approximately 5 months use. Are they worth repairing in shop? Key is, & no one tells you this, you have to carefully, gently plug them in & let them be until fully charged. Don't move them while charging because those charging ports are so so delicate you will “wiggle" yourself right into a broken tablet. Buyer beware!
Puan 0
Yorum Ekle
Yanıtını ekle
LaRivieresr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,002
