My device cannot turn back on
Hi.. i use Huawei Ascend G7 about 6 month. I want turn on my device after suddenly off it cannot turn on anymore. Can you help me?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
estimado amigo lo primero que puede ocurrir es que la bateria como comunmente decimos los tecnicos esta muerta o sea sin carga necesitaras acudir a un sat y que te reanimen la bateria. la bateria pierde toda su carga si no se utiliza durante un tiempo.
espero haberte ayudado
Bu yanıt yardımcı oldu mu?
If you try and charge it and there is a red light flashing, it means that the battery is over-discharged, you should probably go to the phone shop and they can help.
sfdgkjvbnwsv vfweijsfvnw svusfvhsfvkmdfb afoiwefngcv wo sdfkosgsfc nrgoiwretjhdhb sdlkfhSDF neorfghferg sfdpgjszfdh ndlkfgjhwarg bzdb 9sgjdflbm,rgjkn ghkl;gnkgh7gn5fghemlgknsdigndgbndgbv fxhnhnfbn
translated :)
I also am facing the same problem :(
Can anyone help :(
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,432
1 Yorum
Same problem of my phone
Banie tarafından
