Ana içeriğe geç
Bu tablet, Temmuz 2013'te Asus tarafından piyasaya sürülmüştür. Model, ME173X olarak da adlandırılır. Tablette 7 inçlik bir ekran, microSD kart yuvası, MicroUSB yuvası ve kulaklık ucu bulunur.
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 16
3 Yorum
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
tarafından Paylaş
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
tarafından Paylaş
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
tarafından Paylaş
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
ASUS provide zip file and when we run this command it says missing text files
tarafından Paylaş
can you give more detailed information ?
tarafından Paylaş
Yorum Ekle
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
Puan 1
Yorum Ekle
Mei tablet bringt das soeben was tun
Puan 0
Yorum Ekle
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
Puan 0
Yorum Ekle
forgot screen pattern of phone
Puan 0
Yorum Ekle
Yanıtını ekle
linda2222 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 21,826
