power base giving off a burnt plastic smell
After blending with the nutri bullet there is a burnt plastic smell coming from the power base.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may contact Nutribullet Customer Service Department at 855-346-8874 for assistance on using the product or warranty service. (Mon– Sun, 9am–8pm Eastern Time). You will be required to provide the barcode/serial number located underneath your Motor Base
Bu yanıt yardımcı oldu mu?
Mine is not under warranty but smoke is coming from thebase unit
The blade assembly can fail and does not rotate freely, then you get additional friction overloading the motor, hence the smell and smoke.
The blade assembly fails regular,
Karen, could be the motor bearing or the motor winding etc. Unless you take it apart using these guides it will only be a guess.
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 29
Her zaman: 51,479
3 Yorum
I just bought a nutri bullet and After blending with the nutri bullet there is a strong burnt plastic smell coming from the power base. Why?
sandhanamkasi tarafından
Hi I have the same problem, as soon as I started there was a spark and burnt smell. Was your problem resolved? What should I do?
Mansi tarafından
I had that too. Took it back and have the same problem
cecille heath tarafından
