Ana içeriğe geç
Repair information for printers made by Canon.
trouble massage like Ubdate Firmware *Bios Mode*
my printer write a massage when i want to print an on the printer the massage says
Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 52
2 Yorum
Have u solved it? I have the same problem. Thanks
tarafından
plz help i need a help
tarafından
Yorum Ekle
16 Cevap
Filtre ölçütü:
En Yararlı Yanıt
ok then how can I solve this problem plse help how can I do " Ubdate Firmware
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Canon ImageRUNNER 2422 2420"
Bu yanıt yardımcı oldu mu?
Puan 20
2 Yorum:
tarafından
canon ir 2420 update firmware bios mode
tarafından
Yorum Ekle
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
Puan 6
Yorum Ekle
Puan 4
Yorum Ekle
this is all problem solution
Puan 3
1 Yorum:
*Bios Mode*
wait updating F/W
2010/10/28 Vo.01
tarafından
Yorum Ekle
hello i have machine canon ir 2420 , error message update firmware , i am change board usb , fix problem
Puan 2
1 Yorum:
That will work for sure! BUT will cost you a fortune! And yeah - that is much easier!
tarafından
Yorum Ekle
https://www.canon.fr/for_work/mobile-sca...
Puan 1
Yorum Ekle
Here is what you can do. That helped me once.
You need to get to mainboard and find there flash memory. In my case it was chip - 25Q64BVFIG. It contains firmware for that machine.
Then - need to desolder it, reprogram using programmer with support of that type of schemes and solder it to mainboard again.
Downbelow will be a link for dump to download (must mind you - that Canon iR-2420 was in Russia and I'm not sure about differences between US/Canada and European firmwares. Just to let you know that beforehand - that there might be some problems to show up. But I suppose - since machine will finish loading inner software and comes to ready state - you can just figure it out by playing with local/country settings). These are photos before and after (connector melts a little)
- About dump - it's ready to use with your programmer - it's been taken from newly installed machine (not by me - but from guys from similar Russian tech forum). DUMP for reflash memory chip
- About programmer - mine is - TL866A - pretty simple and cheap
Good luck! Hope that will works for you!
Puan 1
1 Yorum:
Here is link to forum Copytechnet - where I originally posted this recommendation
http://www.copytechnet.com/forums/canon/...
tarafından
Yorum Ekle
yep! what if i swap the chip with the one from 2318 ? will it work?
Puan 1
1 Yorum:
Not 100% sure, but suppose yeah, that might work for you.
tarafından
Yorum Ekle
ما حال مشكلة هدا راسالة الة سحب
canon 2420
Message please wait
Puan 1
Yorum Ekle
this is also my problem pleas give me solution
Puan 0
Yorum Ekle
what would be the problem of this and what should i do ?
Puan 0
1 Yorum:
what would the problem of this and what should i do
tarafından
Yorum Ekle
Boa tarde a equipe da CANON, eu tenho uma maquina fotocopiadora canon 2420, ela tinha problema de fonte e ja foi resolvido, so que nao esta a fazer copia, aparece na tela a seguinte mensagem: Update Firmware * Bios Mode* 2010/10/28 VO.10W STARDR 5N
Puan 0
1 Yorum:
Como solucionar esse problema?
tarafından
Yorum Ekle
Please if any body knows the solution on how to fix this problem of (* bios mode * firm ware update ) on IR2420 Canon .
Please E mail me on vifeanacho@gmail.com
Puan 0
Yorum Ekle
i need ir 2420 firmware
help me
Puan 0
Yorum Ekle
https://cloud.mail.ru/public/E3FN/g9Ry4q...
Puan 0
Yorum Ekle
i need ir 2422 firmware
Puan 0
Yorum Ekle
Yanıtını ekle
wendosen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 91
Her zaman: 9,461
