Ana içeriğe geç
2001 ile 2004 yılları arasında üretilmiş bir Apple bilgisayar için 17 inçlik LCD ekran.
My mac display is dimming!
My mac display is at the highest brightness setting. It is about 5 years old, and I'm wondering if there is a bulb or something wearing out. If so, can it be replaced?
Bu iyi bir soru mu?
Puan 1
3 Yorum
Can you comment on the model of the computer?
tarafından Paylaş
It is a desktop display. An Apple Studio 17 LCD that came with the original dual G5
tarafından Paylaş
if you need help taking it apart, i do have a teardown posted for this exact display.
tarafından Paylaş
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
The inverter board is the part which needs to be replaced, a search finds them running about $130 dollars.
If you want an Apple ADC display, it may be less expensive and less work to find a replacement display on eBay or Craigslist. You might even find a larger Apple display for the cost of the repair parts.
You could also consider buying a new LCD - there are many good 3rd party options in the $130 range, and a new device, with newer technology, will probably outlast your G5...
I found an excellent take-apart at: http://mac-guild.org/display-repair.html
The class-action settlement probably no longer applies, as this model has long since been put on the obsolete list, BTW.
Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you David, you are right that it is time to get a new monitor, and truth be told, a new hard drive.
tarafından Paylaş
Yorum Ekle
En Yararlı Yanıt
It's very difficult to replace just the CFL bulb without damaging the rest of the display as you have to strip it completely down to pieces.
BTW you don't have to buy the complete cover, and or frame assembled once you get the old display apart on the back there's size and type information that will let you order a brand new replacement LCD online depending upon the size a new LCD should cost less than $100 for a 12 or 13" CFL probably what's in a machine that old.
N.
Puan 1
Yorum Ekle
What type of mac display is it? most likely the display itself is going bad and the lcd needs to be replaced. it happens to the best of em. :(
Puan 0
1 Yorum:
It's a 17" apple studio display (ADC)
tarafından Paylaş
Yorum Ekle
most LCD's will last about 60,000 hours beecase of there backlights, and if your an avid computer user it's about time for a new moniter anyways
checkout either this site or bestbuy to see if you can recycle it, I know that bestbuy will pay you to recycle your used electronics
Puan 0
Yorum Ekle
Open System Preferences
  • Click on Energy Saver
  • Click on Display
IN energy saver option un-check Slightly dim the display
Automatically reduce brightness
In display section
Automatically adjust brightness
Puan 0
Yorum Ekle
Yanıtını ekle
clinegunk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 4,440
