Fuel level gauge mechanism and repair
I want to learn how Toyota corolla Altis 2008 Model fuel level gauge works and repair it if needed to.
I also want to see how to adjust the Gauge that shows wrong level in the tank.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Boon, the fuel gauge sending unit is located on the fuel pump in the fuel tank of the car. It consists of a float, connected to a thin, metal rod. The end of the rod is mounted to a variable resistor. Take a look on here about how it works. they are really not that adjustable unless you bend the small metal arm. This will no be very exact. I'd have someone measure the resistance of the unit to see what the values are. The only other thing would be to replace the sending unit.
Bu yanıt yardımcı oldu mu?
Thank you so much for your valuable information and time given .. it was a quick answer too, to my question !
Toyota 2003 allion not working fuel meter wirang problem .and fuel pump motor full replas .Desborad meter replies but not working please help me
Im new compelat fuel pump motor full replas .but Desborad fual meter not sho
Thanks but im new Desborad meter compelat replies but Desborad fual meter not sho andno reding is big poblon please solutions help me
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 18,087
