My power button is stuck and is at a slight angle.
Do I need to open the unit for adjustment, cleaning, or something else?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It's probably getting caught on the rim of the hole it's inserted into. See if you can gently move it away from the side it's caught under.
Bu yanıt yardımcı oldu mu?
all the buttons seem to be "off center" as well. Guess I get to open this thing up now.. Thank You!!!
I am having a similar issue...my power button seems to be stuck. It won't click. It's not crooked. I've replaced the power supply. That didn't help. Can you please suggest something I can try to fix this? I bought a new button, should I go ahead and replace it? Or is it something simpler maybe? Thanks in anticipation of your answer. Kirstie :)
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 153
