Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Can someone explain how to test a PCB for short circuit?
Hello again ifixit,
Trying to begin repairing some water damaged/ no power phones here. iPhone 5/5c/5s. Can anyone point me in the right direction of diagnostics for a water damaged board? I'm really not sure how to find a short, or an open trace as I have no idea where on the board to measure voltages. Are there schematics out there that show all the correct voltages? I have not been able to find any.
I guess the first part I want to know is, should there be continuity between the battery terminals on an iPhone 5/5c/5s board? I've seen people talking about that as a way to find if you board is shorted, is there any value to this? I also read about hooking up an external power source(low voltage, high current) and then replacing whichever components start overheating.
I guess I just need to know where to go to start making sense of these units with no signs of life. Its a mess at the moment. Thanks in advance
Bu iyi bir soru mu?
Puan 1
8 Yorum
hi. i have all the schematics for the iphones and ipads. let me know the one you want and i'll mail it to you.
tarafından
What, really?! That would be awesome! I'm really looking for iPhone 5/5c/5s schematics. iPad 3/4 would also be very cool.
tarafından
can you give me your email address so. will mail them to you
tarafından
joshuadavid1993@gmail.com
I really appreciate it
tarafından
I've got the same problem I ask for help
and my email smsm6666666@yahoo.com
tarafından
3 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Short circuits produce heat, so feel for heat.
Bu yanıt yardımcı oldu mu?
Puan 3
4 Yorum:
I'm really wondering how to test for a short with a multimeter, some of the components are so small that its hard to find where the heat is coming from
tarafından
Not practical. You have to test them individually out of the circuit, which means desoldering everything you see on the board.
tarafından
I see. For some reason I did not realize I need to take them out of the circuit. One other small question, I have a ton of iPhone 5's that seem to have a serious short right above the sim card area. They get burning hot, but I can't single out the component. It seems like a common issue. Any ideas?
tarafından
Could be the CPU, U2, or a million other things. I can't tell you without seeing it.
tarafından
Yorum Ekle
Yanıtını ekle
Josh White sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,351
