Ana içeriğe geç
Acer Aspire 8920, 2008 yılında Acer, Inc. tarafından piyasaya sürülen bir dizüstü bilgisayar serisidir. Acer, Yeni Taipei Şehri, Tayvan merkezli bir elektronik şirketidir. 8920 modeli, Gemstone serisinin bir parçası olarak piyasaya sürülmüştür ve Acer tarafından üretilen 18,4 inç ekranlı ilk dizüstü bilgisayardır.
laptop resetting during install
can anyone help my laptop keeps switching itself off and restarting during restore even if i use a stand alone windows not restore i have even tried from usb stick windows 7 BUT if iinstall linux or hackintosh its fine installs ok just i even have replaced the hard drive twice does it on windows any ideas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
i think you forgot boot disk uttulities run over it
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Hello richardapayne
Sounds like a driver, a memory problem (not to sure why other OS's work though)
Does it restart at the same spot during the installation? If yes what is the installation doing at this time?
I would try running memtest86 for at lease 5 passes (I leave it run all night.)
http://www.memtest86.com/
When in Lunix run psensor to check your CPU temps. When installing Windows the CPU can max out and if the CPU gets to hot the computer will reset or turn off.
http://wpitchoune.net/blog/psensor/
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
My aspire 8920g restarting with power is on.
In the mode safe works ok.
Puan 0
1 Yorum:
I had the same problem and after a bit of research I found out that disabling the two cpu cores in the device manager in safe mode solves the problem. Here's the link to the source: How to fix a notebook that freezes when plugged to AC power?
tarafından
Yorum Ekle
that common in 2008 models. try to update bios. https://www.acer.com/ac/es/ES/content/su...
Puan 0
Yorum Ekle
The answer to this Reboot problem is the Capacitor located right under the CPU. Setting the CPU to use only a single core cpnfirms this is correct. There is a repair video on youtube that shows how to do this. The Original capacitor (Single Unit) is peeled off the board and replaced with 4 x 330uf - 2.5v Tantalum capacitors in its place.
It takes patience and care to complete, but is NOT too hard for most enthusiasts.
Whats needed: 2R5TPE330M9 330E 330 330UF 2.5V D SMD tantalum capacitors
Puan 0
Yorum Ekle
i have the same problem while trying to reinstall windows vista home premium because they got corrupted during a windows 10 installation and trying to boot results to a restart
Puan 0
Yorum Ekle
Yanıtını ekle
richardapayne sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 2,597
