Ana içeriğe geç
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
6 Soru Tümünü görüntüle
Soru Kapandı
Why am I unable to make the menu selections with menu button?
The menu button is known to stop functioning properly at times. If the menu options that you attempt to select are not being selected or the wrong options are being selected, then your menu button is malfunctioning.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The menu button may not be centered. If this is the case, then all of the selections will have difficulty being selected. The menu button must be removed and reattached centered in order to correct this.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 65
