Ana içeriğe geç
1.4 GHz işlemcili, 1280x800 piksel LCD ve 149 ppi çoklu dokunmatik ekrana sahip 10.1 inç Samsung tablet bilgisayar. Cihazın model numarası GT-N8013ZW'dur. Ağustos 2012'de piyasaya sürülen bu cihazın tamiri oldukça kolaydır.
Stuck in a boot loop
Mine is stuck in a boot loop and I can't get to recovery mode by pushing the power and volume button, I can only get to download mode. I tried flashing ROM as described by XDA Developers, and it said it passed, but it's still in the boot loop.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
Mine also has a boot loop Too and it's unusable
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds like your phone is in a boot loop and you're unable to get it to boot into recovery mode. This can be a frustrating problem, but there are a few things you can try to fix it.
Method 1: Force reboot
The first thing you can try is to force reboot your phone. This will usually clear any temporary glitches that may be causing the boot loop. To force reboot your phone, follow these steps:
  1. Press and hold the power button for about 10 seconds.
  2. Your phone will power off and then power back on.
Once your phone has rebooted, try to boot into recovery mode. If you can boot into recovery mode, you can then try to flash the ROM again.
Method 2: Flash the ROM using a different tool
If you can't boot into recovery mode, you can try flashing the ROM using a different tool. There are a number of different tools available, so you'll need to find one that is compatible with your phone. Once you have found a tool, follow the instructions to flash the ROM.
Method 3: Take your phone to a repair shop
If you've tried the above methods and you're still having problems, you may need to take your phone to a repair shop. A repair shop will be able to diagnose the problem and fix it for you.
I hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
lewie2s sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 862
