Ana içeriğe geç
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Soru Tümünü görüntüle
Why do I have a gray horizontal line on my screen?
I have a gray line about one pixel thick that goes horizontally about half way across the screen of the iPod. Where should I first look in diagnosing the problem?
Update (12/14/2009)
I apologize for the terrible picture quality. The line is between "backlight" and "brightness". It isn't a crack in the screen. Thanks for the responses.
On a side note:
Any idea what causes this issue?
Bu iyi bir soru mu?
Puan 1
4 Yorum
Can you post a picture so we can see if it looks like its damage to the actual screen or not?
tarafından
My ipod had multi-coloured lines across screen. Followed instructions to hold down on-/off button at same holding centre button until apple symbol appears. Did it a few times, nearly gave up but eventually the lines cleared. THANK YOU.
tarafından
broken inside screen
tarafından
just a guess but i figured it would be bigger
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Q: is the gray line there no matter what is being displayed?
I would guess it's likely a hardware failure in the LCD module, more specifically one of the outputs of the LCD row drivers, as I described in my answer to a similar question
unfortunately it's unlikely you'd be able to repair this yourself without replacing the whole LCD display module.
one thing to try - does slight pressure directly on either edge of the glass where the dead line is bring it temporarily back to life? - that might mean it's just a physical break in a connection of one output. bad news is it's likely impossible for you to resolder, the drivers are often bonded directly to the glass.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I hade the same thing on my 7th gen iPod nano. They looked like dead pixels but they weren't. Then I got these dots on my screen after a long time of using it day after day the lines went away.
tarafından
Yorum Ekle
I have a white lines going across my iPod touch 3rd generation and when I lock my screen and my screen goes white HELP!!!
Puan 0
2 Yorum:
I have white lines going across my iPod touch 3rd generation and also when I lock my iPod the screen goes white ..., HELP!!!
tarafından
The iPod nano 3rd generation has screen problems.
tarafından
Yorum Ekle
Yanıtını ekle
Reese Reimers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 26,710
