Ana içeriğe geç
Samsung's fitness-oriented smartwatch, featuring a curved super AMOLED touchscreen display. First released in April 2014.
35 Soru Tümünü görüntüle
Soru Kapandı
Corrosion on charge point.
Between sweat and water the copper charging spot on the watch has appeared to have corroded. It hasn't caused any issues with charging or anything but I want to find out how to clean it or repair it. Does anyone know of a good way of doing this? I'm thinking of using some isopropyl alcohol.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Why fix it if its not broke right?
Here is the guide for teardown of the Gear Fit.
Samsung Gear Fit Teardown
Once tore down you clean it with some isopropyl alcohol 91% at least.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
A short fix as well.... if the gold/copper contacts on the back of the Fit itself are corroding like mine did, use a stiff pencil eraser and rub at the contacts carefully. If you do this before the corrosion sets in too much, you should be able to prevent it, with regular cleaning.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 2,241
