Ana içeriğe geç
Motorola'nın orta ve üst segment akıllı telefonlarından oluşan Moto X serisi için onarım bilgileri.
Fix for headphone jack not working
For anyone who has come across an issue where plugging their headphones into their moto x and then the audio either stuttering between the headphones and the phone's speaker, or just not playing through the headphones at all. The issue is a small metal clip at the top of the inside of the jack. It gets worn away and pushed back and stops making contact with the rings on the jack. Here is how to fix that using a small piece of cardboard or other non-conductive material:
Hope this helps for anyone desperately trying to figure out how to save their trusty moto x.
EDIT:
The link above no longer works, so I posted a photo illustrating where to insert the spacer: http://imgur.com/a/3bHEc
Bu iyi bir soru mu?
Puan 6
9 Yorum
You are the saviour ! My Moto E2 now works - only the left headphone speaker was working, now both are back in action !! Thanking you!
tarafından
Technical assistance charged me 60 Bucks to fix this, luckly i saw this before making any real. Thanks a Lot!
tarafından
Thanks so much! I'm pretty rough with my phone when I'm out running. I used a small piece of plastic and pushed it behind the contact after pulling it out with a safety pin. Works fine again!
tarafından
Awesome. It fixed my Moto G3 too. Thank you so much. Twas too easy
tarafından
Hey, is there a way you can update the link? When I click on it it takes me to a broken link! I would love to be able to fix my headphones :)
tarafından
4 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
reply post so I can mark this as "solved".
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
can you descriibe the process? link doesn't work.
tarafından
I just updated the post with a new link:
tarafından
Can I use a safety pin to pull the clip
tarafından
Got a Motorola e6 plus and when I connect me headset the sound come out me phone but sometimes it just work but stop a few minutes later
tarafından
Yorum Ekle
En Yararlı Yanıt
Sometimes there even a simpler solution, My headphone jack was having all sorts of issues. I took a flashlight to look inside and lo and behold pocket lint had built up inside the jack. I used a wooden toothpick to clean it out and had no problems after that.
Puan 3
1 Yorum:
Nevermind! I just saw the updated link! Sorry and thank you!
tarafından
Yorum Ekle
Brian, this link doesn't work anymore. Can you describe your fix or maybe post it elsewhere?
Puan 0
2 Yorum:
Sorry I never saw this! I've updated my post with a picture to illustrate what I was talking about:
tarafından
Yorum Ekle
How do I take off my back of my phone so I can get the headphone jack thing out of my phone so that way I can listen to my music and watch my movie
Puan 0
Yorum Ekle
It's a workaround, not a solution.
We all have old phones around. Find one that DOES work with headphones.
Use HOT SPOT to connect to your Motorola.
Now run your music app on the old phone with streaming through the hot spot. Works great!
Puan 0
Yorum Ekle
Yanıtını ekle
Bryan Woods sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 26
Son 30 gün: 141
Her zaman: 117,093
