Ana içeriğe geç
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
LCD replacement half screen
I have a Samsung Galaxy tab s 10.5 SM-T807R4 with Half screen half side of the screen works well and the other side white with multi line
the touch screen function works well in both sides
this looks like this link for another tablet
http://www.slatedroid.com/topic/37131-dr...
i think i need to replace the LCD.
the screen has no cracks looks good
is there a video or some guide i can follow to do the repair ?
please help me out
thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It can be also a flex cable or flex cable connector problem. So check them before buy replacment display.
Some times flex just slides a litle bit out from connector causes problem like this.
If a tablet was droped or bended than lcd control board and lcd connection flex can be damaged or lcd glass edge cracks causing the problem. This you can not see from outside or just removing back. Anyway in this case you need new display assembly which comes glued with midle frame and home button, so just move board and other staf from old to new and that it. Do not buy just display without frame from china guys because the price is almost the same and you will need to glue it with frame in correct position. One mistake can damage new display.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hello Lito771.
Unfortunatly for me, I bought the display assembly from china guys, without the frame, as I didn't noticed the difference, and also because no one else had it in stock anyway. So I need to separate the frame from tablet from the broken screen first, and then glue it to the new digitizer. Is there any tutorial or instructions about how to do it ?
tarafından
Yorum Ekle
matrix, looking at your attached image you are right. you will need a new LCD.
Puan 0
Yorum Ekle
Yanıtını ekle
matrix sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,849
