Ana içeriğe geç
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Soru Tümünü görüntüle
Soru Kapandı
iPad Mini broken battery?
I was working on an iPad mini, a simple digitizer replacement. In trying to remove remnants of glass (the screen was in pieces) I accidentally punctured the battery. A strange smell came from the battery, so I put it in a Ziplock. I've already called Poison Control and I'm fine, but now the battery is totaled. I do have another iPad backing, but the logic board is iCloud locked. The battery in there is fine though. My question is, is there a way to fix it without buying a new battery, and if not, could I take out the logic board and transplant it into my other iPad?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
As long as the iPad's are the same model, you can transfer the logic board and it will work fine.
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
I know, but the charge port is connected to the logic board with what looks like a circuit connected to a piece of electrical tape in the iPad mini- do I have to take it out too, or can I just take it off the board?
tarafından
You shouldn't have un-accepted his answer. But to answer your other question, the charge port is soldered on to the motherboard. You will just move it over with the motherboard.
tarafından
Sorry! I'm new here.
tarafından
Okay. So I can just unscrew the charge port and move the whole assembly?
tarafından
Yes, you can unscrew the charge port, carefully peel it up from the back housing and remove it along with the logic board.
Ifixit has logic board replacement guides for the iPad mini, which will go through the complete process of removal. This guide is for the iPad mini 1st gen wifi iPad Mini Wi-Fi Logic Board Replacement
If you have a different generation or version, they have hose available too.
tarafından
1 tane daha yorum göster
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 158
